** Saitek Pro Flight X55 **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have had confirmation today that our long awaited stock for the Saitek X55 Rhino H.O.T.A.S. Flight System is due in the next few days.
We have a massive amount of pre orders for this product as it presents pro simulation peripherals at a very attractive price point.
To celebrate this, we are giving one lucky customer the chance to WIN their pre order - free of charge!!!
All you have to do is pre order your X55 from Overclockers UK and you could be in with a chance of a full refund on your X55.
Currently, 50% of our stock allocation is assigned to pre orders. Anybody with a pre order currently will automatically be entered to win.
This is an incredible offer and one not to miss. Stock is EXTREMELY limited with all Saitek flight sim peripherals and we expect there to be little/no remaining stock for anyone who hasn't pre ordered.
Saitek Pro Flight X55 Rhino H.O.T.A.S. System @ £169.99 inc VAT
Military-grade Flight Sim Precision
Inspired by controls found within actual fighter planes, the next-gen X-55 Rhino H.O.T.A.S. System for PC provides utmost control over simulated aircraft. Built to the same exacting standards of Saitek's award-winning Pro Flight accessories range, the X-55 Rhino delivers a multitude of customizable options never before seen in an H.O.T.A.S. System. Whether flying a modern fighter, single- or multi-engine aircraft, or even a retro single-seat plane, the X-55 Rhino supplies all the control surface options required to achieve the exact level of aerial performance aspiring pilots demand.
Enhanced Stick Accuracy
During virtual flight – just like true flight – the accuracy of an aircraft's control surfaces is of paramount importance. The X-55 Rhino's control surfaces are incredibly accurate, courtesy of an all-new 16-bit aileron and a 16-bit elevator axis, each employing hall-effect sensors. Developed from the ground up, Saitek's 16-bit axis solution enables extremely precise flight.
Adjustable Stick Force via Advanced 4-Spring System
A ground-breaking, adjustable stick spring system allows pilots to alter the force required to move the stick. Four springs of varying resistance are included to provide a total of five different options. Choose the spring – or no spring at all – which best accommodates your style of flying.
Twin Throttles with Friction Adjuster and Throttle Lock
Using a twin-engine throttle controller is the only suitable method for manipulating a virtual twin-engine aircraft. The X-55 Rhino boasts twin throttles – ideal for situations in which your primary engine is disabled and you're down to one – and also provides the option to adjust the friction required to move them. And if your aircraft of choice is single-engine, a handy throttle lock effectively converts the twin throttles into a single unit.
Bonus Toggles and Rotaries on Backlit Throttle Base
Flight sim accessories used by today's virtual pilots require the highest level of control and customization. The X-55 Rhino showcases additional toggles and rotaries, not based on any particular aircraft, around the throttle base. Seven extra three-way toggle switches and two rotaries allow you to customize this H.O.T.A.S. System to your own specifications.
Individual USB Connectors
The X-55 Rhino's stick and throttle units each utilize their own separate USB connection, offering greater flexibility during customization. You're free to situate the controls exactly where you want them, without the need to keep them tethered to each other.
H.O.T.A.S. Configuration Software Enables Programmable Controls
Saitek's new software provides the ability to completely customize all of the X-55 Rhino's axes and buttons. On the axis side, you can adjust deadbands and response curves to fine-tune axes to respond just like an aircraft's real-life counterparts. On the buttons and toggle side, you can assign any number of in-sim directives, such as speed brake, flares, target lock and pickle weapon. The software also allows programmability for an array of mouse and keyboard commands – from basic single-key inputs to very advanced, timed, and macro commands.
Build the Ultimate Virtual Cockpit
Transform even a modest PC into a virtual cockpit and experience the staggering realism of different flight and emergency situations – complete with realistic weather and flight conditions. Using the X-55 Rhino as a foundation for Saitek's modular accessories, easily add Combat Rudder Pedals and a multitude of Switch, Navigation, and Instrument Panels to fully customize your flight simulator. Commercial or private, seasoned or novice, you have the ability to equip your flight simulation setup with all the essentials needed to vastly improve your skill set and muscle memory.
Product Includes:
- X-55 Rhino Stick Unit with USB Connector Cable
- X-55 Rhino Throttle Unit with USB Connector Cable and Green Backlighting
- Spring System with 4 Springs of Varied Resistance
Compatible with ALL Major Flying Games with the Saitek X-55 H.O.T.A.S. Configuration Software,
Only £169.99 inc VAT.
ORDER NOW
Sooo tempting
I love flight sims but have never played with a proper joystick
Spent so long configuring an Xbox controller to work properly!
It is a lot of money though
Is it worth it? Is this the best product to go for?
THE best is probably the thrust master warthog. But that's north of £300. This seems to be the happy medium between features and price. Get a crappy stick first to get used to before going bigger id say. Everyone sucks with a HOTAS at first. But that temporary downgrade in ability results in a long term gain that KB/M or a controller will never reach.
You don't appreciate a premium product until you've used a crap one. Just like jumping to a top GPU or getting an M5 as your first car.
Saitek is not a premium manufacturer. They are mid-tier with a poor reputation for customer service backup.
Thrustmaster are more expensive but their after-sales support is widely regarded as excellent.
The Warthog is unquestionably the better built HOTAS, though by no means perfect (everything is built to a price), but if money wont stretch that far the X-55 should be an improvement on the X-52 and more flexible than the X-65.
Was it the Warthog or the X65 (or even both) that lack the rudder twist on teh stick, requiring you to drop £300 and still need *another* however-much for a set of pedals?
Having tried out the X55, it is a pretty damn nice stick for the money!
See darket69's comments about the design, though.
Anyone spending £300 on a warthog is going to be using pedals. The stick is a replica of the real thing, and the real thing doesnt twist because we use pedal rudders.
The X65 was a pressure stick, so i doubt that had twist either, though im not sure as i've not used on. Again though a stick in the £300 region, anyone that into flight sims will be going all out, pedals, trackIR, multi screen etc.
***WARNING***
Oh no, see below post from Darket
"Well , a bit of an update, it seems the x55 has a design flaw, the other day the rudder/twist/yaw started to click , no big deal i thought but this soon turned into a nasty squeaking that got worse with use and with that a certain amount of resistance with it.
Not being one to just return a product for what could be an easy fix i removed the 5 screws ( 2 at the base and 3 up the side) that hold the casing together on the stick , from a brief looking over of the twist mechanism its just a very bad design and will wear out very quickly as its also integrated into the screw type locking ring which secures the stick to the base, mine already has more slack than it should from only about a weeks worth of use. Lubing it with some graphite will no doubt cure the squeak and maybe the resistance in initial movement *however* whilst this may solve the symptoms its still a flawed design and i wouldn't be surprised if Saitek don't revise it in the near future as it seems to be a common issue.
My advice would be to wait and see what Saitek is going to do about it before parting with any money.
But just to make things clear, This isnt an issue of a faulty part, it works as it should , its just a very very poor design."
Great! :( How long have I been looking forward to this joystick. Nice one Saitek...not!
Agreed its s lot of money for a joystick. I'm using the Saitek X52 and would love this but I can't quite justify the cost.
Even though it's far better? Don't get me wrong the X52 is decent but it's not a stitch on cheap sticks like the T.16000M one for accuracy and will be blown out the water by the X55. You are using 7 year old + tech.
***WARNING***
Plenty of videos about these squeaking, I was hoping they'd fix the design by now though.
Not everyone...
I keep debating whether or not to get a Warthog, but I use a corner desk and have neither the space for, nor the inclination toward using pedals... I'm usually the odd one out though! :p
Having handled one quite a bit now, it is WELL worth the money.
Cost for me is simply a matter of saving all the pennies, which will take me a fair while, but most of the games I'd be using it for will just about be released by the time I can afford it anyway, though.
