Same GPU won't work in first PCIe slots in 2 different motherboards?
Hi Kissenger, I've just read through your thread, sorry to hear about your saga.
Could I ask you to go into bios with the gpu in 2nd slot, and configure 1st slot to x8 only.
i'm not sure if this is a hardware jumper or in bios. but once youve done that try the card in your 1st slot.
Just to explain my reasoning .... 1st the original board having a fault , and also the card working at x8. i'm wondering if either the gpu or mb have taken each other out maybe now the gpu will only work on x8 .
my only other advice might be to try a bios reflash on the gpu. if you've had experience with that.
good luck.
let me know how you get on.
Mags
Hello Mags.
I've just flashed the GPU BIOS and although the flash happened without a hitch and the card still works in slot 2, it's still not recognised in slot 1.
I will try setting the first slot to x8 but I can't seem to find that option in BIOS and there's nothing about it in the manual.
So I had a (rare) brainwave: it occurred to me that although I don't have a spare GPU to try I do have a PCIe x1 sound card... so I tried that in the 'dead' PCIe slot and it works just fine.
Safe to say the problem was the GPU all along? If so, I'll start the RMA tomorrow.
it's a strange one. that's for sure, sorry about the delay, ive been a way a few days.
could be a bit of chicken and egg. shame you don't have a friend you can borrow a gpu off, and try it in slot 1, as x1 isn't a very good test.
good luck
Mags
It could be an issue with one or more of the PCIe lanes on the GPU itself, e.g. when it's running in 8x mode in a secondary slot it's fine, but when trying to run 16x one or more broken lanes is coming into play.
The only way to really prove this though is with a different GPU.
