Same shape, same colour - so why am I looking?
18 Oct 2002
Pembrokeshire
Going to check this out at the weekend :)
Subaru Impreza WRX STI Type RA V Limited
PICTURES REMOVED
So same colour as mine, same shape as mine and the foulest looking rear spoiler ever to grace a classic Impreza (and yes its genuine subaru). So why bother?
Because its probably one of the best and most well equipped Classic Imprezas ever to be built.
ewww, that spoiler is nasty.
Why not get a P1 or 22B? Much nicer looking cars (although my knowledge on Imprezas isn't the greatest)
Buy it but move over all your styling mods. A non MY99 Impreza looks a bit tired and old but the T, V, W and X reg ones are just great.
22Bs are mega bucks and P1s aren't as good as the Type RA
That is easily, as you said, the FOULEST looking spoiler ever created :o
What's so special about this model then?
Edit - Ah RA's, aren't they the Rally preped ones or something? Stripped etc.
The Type RA is the one rally cars use as a base. Lightweight striped out with far less comforts than the standard model. The V-Limited version adds some of these back and alters the gearing iirc, but keeps the benefits like the closed deck block. The STI also makes 276bhp and has the rather lovely Driver Controlled Centre Differential :D
I'm hoping I don't have to part with much cash plus mine. Mine will go as a whole.
Not sure I'm happy with the P1 spoiler on my car. Obviously the S201 wing on the above car will be coming off but I might just put a mid level one on ala UK turbo.
Apart from mudflaps (a must IMO) and wheel change (Got 18s on mine and never really felt comfortable pressing on - not like with 17s but that might be the tyres) I'm going to keep it as original as possible.
In some ways I wish I hadn't modded my Impreza cosmetically. The one above is IMO very rare and really should be kept "O-natchurel"
Only thing that really puts me off is the APEXI AFC thingy - why just that without a boost controller? If raising the boost pressure doesn't kill a turbo car, being able to fiddle with the air/fuel/advance sure will.
Doesnt the apexi control the boost also, and can be displayed in several different ways onscreen?
I bought a rover 220 turbo coupe at the weekend which had one, and although ive not spent ages faffing that was certainly one of its functions, that model may be different but looks the same!
No, this is an AFC which controls air/fuel. The boost controller made by Apexi is the AVC.
Now I've seen cars with both or the AVC alone but not the AFC alone. I'm hoping its fitted to compensate for any issues the car had with having the cats removed or in an effort to help it digest UK fuel without going POP. Its also got an atmos dump valve which throws the air/fuel out too.
Dale V said:
I actually love the spoiler, keep it if you buy it :)
Its different but just not to my tastes. Technically its probably quite expensive as its genuine Subaru but I doubt its going to be worth that much in reality.
Type R = 2 door
Type RA = 4 door
One 5 year old daughter = 4 door :D
Edit - apparently the rear spoiler was an option from new!! Still coming off though.
not disagreeing with you
but dont early RA's look like this ?
thats a '96
and later ones look like this ?
Up to version 4, the low/mid spoiler was used. Version 5 had the high spoiler with a flat cross section and version 6 had the high spoiler with the flip up in the cross section.
V5
V6
Car I'm looking at is version 6. V6 have blue dash surrounds.
I'm thinking of just going for the low/mid one. High spoilers increase drag.
the STI 6 spoiler you've posted above isnt the one thats on the car though ?
so isnt it aftermarket
or was it on the jap options list or something
