Hi
I have had this SSD for almost 3 years as an Steam gaming drive on my various PC's.
Last night my X99 based system with Windows 10 would not boot up the OS. Windows would just hang with the logo and spinning dots.
As soon as I unplugged the 840 pro from the Motherboard Windows 10 would boot up fine from the primary drive (Samsung 850 Evo).
If I plugged in the 840 Pro again the same error would occur and the bios would not pick it up and Windows 10 would refuse to boot from the 850 Evo drive its installed on.
This morning I took my Crucial 512GB SSD gaming drive from my laptop (P35x) hot swappable bay and put in the 840 pro SSD.
The same error occurred and Windows 10 refused to boot on my laptop from the Micro Raid SSD that came with it, the same error as above with Windows logo and spinning circle.
However the laptop bios did detect the 840 pro drive but only detected it as 0.9GB in size.
I swapped the SSD back out for the Crucial on the laptop and Windows 10 booted just fine with the Crucial SSD detected.
So I am coming to the conclusion that my 840 pro is knackered. I have got one more test to do which is try on my original Windows 7 PC just to rule at minor possibility of Windows 10 issue.
I just want to know if anyone else has had similar issues with secondary drives causing Windows 10 failure to load up. I don't quite understand as Windows 10 is installed on a sound drive but still fails to boot when this secondary drive is plugged into the motherboard.
I think the 840 Pro warranty is 5 years but I am loathed to send it back due personal data on the SSD.
Are there any other tests I can do? Would it be possible for me to get the data off this drive?
Thanks
Jim
Thanks
Jim
