Samsung 845DC PRO SSD. Datacenter grade Solid State Drives
22 Apr 2014
Along with the 845DC EVO drives Samsung have also launched the 845DC PRO range which are designed for a Datacenter where you are writing a lot of data to the SSD each day. These have faster write speeds and are geared up for this situation. They come in two sizes. A 400GB unit and a 900GB unit.
Samsung 400GB SSD 845DC PRO SATA 6Gbps Solid State Drive (MZ-7WD400EW) @ £569.99 inc VAT
Samsung SSD 845DC PRO is designed for server and centers. 845DC PRO's superior performance and industry-leading reliability are suitable for the most demanding data center uses. Especially, 845DC PRO's significant enhanced endurace through 3D V-NAND technology and reinforced random write performance will provide the best optimized solution for write-Intensive applications with heavier workloads.
Features:
  • Application: Mixed and write-intensive usages are recommended
  • Interface: SATA 6Gbps
  • Form Factor: 2.5 Inch
  • NAND flash memory: Samsung 3D V-NAND 2bit MLC
  • DRAM cache memory: 512MB
  • Sequential read: Up to 530MBps
  • Sequential write: Up to 460MBps
  • Random Read (4KB, QD32): Max 92,000 IOPS
  • Random Write (4KB, QD32): Max 50,000 IOPS
  • Mean Time Between Failures (MTBF): 2,000,000 Hours
  • TBW: 10 Drive Writes per Day (DWPD)
Only £569.99 inc VAT.
ORDER NOW
Samsung 900GB SSD 845DC PRO SATA 6Gbps Solid State Drive (MZ-7WD800EW) @ £1,199.99 inc VAT
Features:
  • DRAM cache memory: 1GB
  • Random Write (4KB, QD32): Max 51,000 IOPS
Only £1,199.99 inc VAT.
ORDER NOW
