SAMSUNG 940BF
12 Mar 2006
NFA
Does anybody else have this monitor?
I recently bought one and i get SEVERE ghosting when i play games, every object with an end ghosts pretty badly!!
best thing to do it, scrap it, and get a tft :p
Am sure badass will tell you what to get, he sleeps with monitors
there were some reports from another user recently about some bad overdrive trailing being evident on the 940BF with a lot of white halo-ing and ghosting. have you checked whether running at 60Hz or 75Hz makes any difference? The other user found that turning off the "overdrive" settings in the OSD helped get rid of the overdrive artefacts, but it depends whether it is this, or something else you are experiencing
I did try changed refresh rates and res's but nothing changed.
How do i turn off the overdrive settins?
