Hi does anyone know if this drive comes with the latest firmware installed, as the earlier sizes had issues, I intend to use it with a PS5, hence updating the drive's firmware would not be easy.
When I ordered my Samsung 990 Pro 2TB, it came with the latest firmware on it. I'm not saying that yours will, but I've not had any updates for my drive since I bought it in the summer, so it should be safe to say that your drive will come with the latest firmware too.
Of course, you should check the drive before using it to make sure.
There are accounts of people using a Crucial P3 Plus in a PS5 as its gen 4 PCIe so you may want to look into that further before splashing out on a Samsung 990 Pro. The Crucial P3 Plus 4TB can be had for £163.99 right now.
