- 16 Oct 2018
Hi, I ordered this a few weeks ago but not got round to installing it. Anyway, I was looking at how to do a firmware update on it if needed and came accross quite a few comments about issues of degradation.
Does anyone have this ssd and does it run OK?
From reddit...
Samsung notes; The new 990 PRO 4TB SSD has a different firmware version 0B2QJXG7, due to the change of the NAND process (V7-> V8), but all 990 PRO V7 / V8 products support equal function and equal performance at the same capacity.New version firmware 0B2QJXG7, there is no updates available, and does not have degrading issues!
Only if you have an 990PRO with old firmware 0B2QJXD7, i urge you to install the newest firmware, 3B2QJXD7, if not your drive will die slowly..."
Thanks
s
From reddit...
Thanks
s
