I just bought a new Spin Point (Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA))
My problem is that I cant get windows to boot when I plug it in??
Hardware:
MSI neo2 platinum
seagate 160gb sata (plugged into sata 3) boot priority etc
samsung 250gb sata (plugged into sata 4) cant find any slave options i assume this is because its sata
ive added the 1.5gbs speed limiter jumper, set the hdd to large in bios, enabled and disabled raid. windows just wont boot with it plugged in.
its odd because its almost as if it loads the first bit of windows as i sometimes get a very dark image of the windows boot screen and i hear my seagate start to read, then it stops.
in the bios though i can hear a very low/deep throbbing noise. this is the samsung as i unplugged it and it went away.
Am i missing something?? how do i get this thing to work??
Hardware:
MSI neo2 platinum
