Samsung EVO and Rapid Start
29 Aug 2004
Alpha centauri
Has anyone used two Evo"s In a raid 0 setup and with the rapid start option for evo drives set to on. If so do you no if it will work with a raid setup, because at the moment it can only be used on one evo drive and not multiple Evo drives in the system.
RAID0 Evo's and you still want RAPID mode enabled? You mad bro?
Yes I know :D but it was showing in some of the benching with rapid mode on that it was maxing out the sata 6 bandwidth, I was thinking that if you raid 2 evo over 2 sata it would offer more bandwidth.
Well it looks like it will be a non starter until Samsung upgrade the software ( RAIDmode sets is not supported as an accelerated drive. Rapid Mode) I will just stick with a single Evo for OS with Rapid on.
What are you using the drives for?
I'd imagine two in RAID 0 would generally be faster...
Although frankly I don't think you'd be able to tell the difference between a single EVO, RAID 0 or RAPID mode...
:confused:
I only have the one Evo was thinking of getting a second but with Rapid only working on one drive, I would have liked to get it working on 2 Evo by using Raid0 but no joy it would seem.
