Samsung Evo Plus 2TB Heatsink Needed?
7 Jan 2003
Gold Coast, Australia
Hi All,
Got a Evo Plus 2TB and noticed it is running quite warm, anywhere between 60-78 degrees depending on whether it is idle or under load.
Samsung Magician reports it as too hot the entire time.
I have it installed in the rear slot on my motherboard (see signature)
Should I put a heatsink on it, if so which one?
I just use these. They are cheap and work perfectly well. They do a lower profile one too that is only 5mm thick. They cost aroung a fiver each.
Placing them on the front in the air flow does make a difference and if there is no slot on the front then a PCIe riser card is a good plan.
As mentioned I have a Mini ITX board, so I don't have the luxury of an extra PCIe slot.
I have moved the drive to the front M.2 for the time being which has a built in heatsink, temperatures have dropped substantially.
The problem is this is the PCIe 4 slot and I'll have a Gen 4 drive going in eventually so this will only be a temporary solution at this stage.
I have noticed EKWB have some slim heatsinks, anyone used them?
