Samsung evo ssd 250g
8 Apr 2017
I have just installed Samsung 850 evo 250gb SSD.when i look at the over provisioning section,using the magician,it does not show any way of enabling it such as a radio button.It does say using a raw partition may damage your data,but no way to alter or create an over provision partition
You can do it manually via disk management.
right click computer > manage > disk management
Right click on the SSD space > shrink volume > enter the amount of space you want to shrink it by.
in the software I think It defaults to 10% of the total space (cannot find it in magician 5.0 but I know it has it in version 4.7)
once you have set the amount click on next.
this will then create a area at the end of the space which is unallocated, leave it as it is and the SSD will use the unallocated space for the over provisioning
