samsung f3 failure
27 Mar 2010
I will never buy a SAMSUNG drive again.
I used to have a f1 320 HD322HJ on my old socket 939 and intel system, then one day from no where upon system startup, massive clicking from the drive so shutdown the pc, and hoped there was no damage, unfortunately upon the next poweing up it was offically dead, arm dropped on the platter.
Almost a year ago i bought a samsung f3 1tb, Been using it in my am2+ system, just upgraded to a z68xp-ud3, and guess what happened today!!!!!
Just found out that there is a firmware which solves the problem with these drives and others from sh...ing themselves on an amd 850 chipset or intel h67-p67-z68.
Luckily I keep a regular backup using my spare re2 and blu-ray discs.
If your firmware is 1aj100e4, then be wary of this problem.
How do you view the firmware version number? Its not something I've ever had to look for. Got me a little worried, just this last week I replaced a drive with an 1tb F3 and I'm now getting painfully slow boot times. Wondering if it could be something as simple as a firmware issue.
So you won't buy a Samsung drive again because one failed on you and the other had a firmware issue? Some drives do have issues. I have had a Maxtor fail and 2 x Samsungs, but then I have owned more Samsungs.
