SAMSUNG HD103SJ
18 Feb 2004
Lincolnshire
does this seem abnormal to you ?
Open Disk
Test : RD-Read
Executing
Block start at 821289472 time 521ms
Block start at 821289728 time 416ms
Block start at 844098816 time 439ms
Block start at 844099072 time 422ms
Block start at 1640569856 time 431ms
Block start at 1640570112 time 416ms
Block start at 1667786752 time 440ms
Block start at 1667787008 time 421ms
im getting some slow downs and mini freezes opening folders and general images, txt, files etc
Just to let you know i was not convinced the drive was performing normally so rma it to supplier and it is indeed being replaced under warranty after being found as faulty, thought you might like to know as i know you were testing your drive as well.
Did they say why its faulty ?
no i just got an automated faulty under warranty message and another is being sent out, i will try ringing them and find out exactly what failed.
