Samsung LE40M86DB Optimum Settings
Used those settings off hdtvtest today. Only used them on sky+ and freeview.Sky looks pretty good considering its a scart connection. Scrubs looks esp good. Football is alrite, theres some ghosting on dark colours but nothing to ruin your viewing.
Found this on avforums,It lets you control telly on/off and volume with sky+ remote:
Depends on the version of your remote.
If there is no version information under the battery cover then assume its version 1.
version 1 code is 088
version 4/5/6 code is 646
sky hd remote rev.8F is 840
3-digit codes are entered like this:
1. Turn on the TV
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the red LED on the Sky remote blinks twice.
4. Enter three digit code from list for the TV (early versions now flash twice).
5. Press select to submit the code (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions
