26 Feb 2017 at 16:14 #1 Digital X Digital X Soldato Joined 25 May 2013 Posts 10,159 Location Kent. With the new Magician software and cannot seem to find any settings, I need to alter the Performance/Reliability options etc. My software has a picture of the SSD as a background, thanks! The old one was a lot easier.
26 Feb 2017 at 16:15 #2 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 33,054 Location Rutland New one doesn't have any of those settings. It's rubbish.
26 Feb 2017 at 16:18 #3 Digital X Digital X Soldato OP Joined 25 May 2013 Posts 10,159 Location Kent. Oh blast.. I think I needed to alter a setting to solve a GTA V memory issue. Can I get the old version back or is it best to leave it?
26 Feb 2017 at 16:21 #4 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 33,054 Location Rutland Yeah pretty sure you can just switch back by uninstalling the new one and reinstalling the older one.
26 Feb 2017 at 17:47 #5 Digital X Digital X Soldato OP Joined 25 May 2013 Posts 10,159 Location Kent. OK thank you for the help buddy.
6 Mar 2017 at 23:54 #6 geordiejc geordiejc Associate Joined 1 Nov 2013 Posts 861 Does this software make any REAL difference for game loading times? i used to use this software on my samsung 840 pro. i've bought an 850 evo 250gb today so may consider installing it, if it speeds the drive up?
7 Mar 2017 at 06:34 #7 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,421 I only have it installed for firmware updates and nothing else. all it does it give you shortcuts to areas to can get too through windows
8 Mar 2017 at 21:53 #8 goodl goodl Permabanned Joined 21 Dec 2007 Posts 829 Location GB upgrade to the new version killed my drive when i did an optimise, i had a month left on my warranty
