Samsung Magician
30 Dec 2012
midlands
Hi All,
Got my new rig yesterday and I'm confused about enabling TRIM on Samsung Magician.
On a previous rig 840 the magician gave me that option but on my256GB 840 Pro I cannot find where to enable TRIm or disable frag?
not sure but if its win7/8 you can run windows experience index and it disables defrag and trim should already be enabled
to check for trim run ssdlife and it will tell you
start/control panel/system and security/system
then click the link for windows experience index and run test
