Samsung N510 :)
13 Dec 2002
Newcastle upon Tyne
Well its arrived, just swapped the hdd and ram, will get some more pics and info as soon as win 7 is installed :)
looks sexy!
how easy it to switch ram?
i know it'll be a push, but if possible, can you let me know how cs3 or vegas works on it?
cheers with envy :)
looks sexy!
cheers with envy :)
sure no problem
ram and hdd are easy, 3 screws to expose both, swap the ram out and remove caddy and sata adapter (it turns the power and data connections through 90 degrees) and bobs your uncle :)
wow looks impressive!
Dont know if you saw my last question, but could you please let me know what the speaker quality is like and if there is a sim slot (probably behind the battery)
Thanks
Thanks
theres no simcard slot i knew that before I bought it but wouldnt use it anyway, bt via my mobile is perfectly good for me :) will let you know about sound.
Ion chipset, atom processor, 1gb ram, sata hard drive. Google it if you want to know more. Very similar to the hp. I would choose the samsung over it, because I like their N range. Refer to the epic NC10 thread to see why.
It looks very nice OP. Feel a little twinge of regret for going for its little brother.
The 510 is new as well. You've got to ask more specific questions, which parts of the specification? Same processor/ram/graphics. Same/similar screens/wireless/ethernet. Probably different batteries. Not much in it, but I would still choose the samsung.
just trying to get a few things setup and hopefully ill be away, the only thing win 7 didnt pick up was something to do with the chipset (available from nvidia) and the wifi wasnt recognised other than that it was plain sailing
Thanks
as far as sound goes I dont find it much different to my old nc10 tbh, maybe a little bit more bass but its never gonna be great, its certainly not bad tho, if i recall its a bit louder than nc10
Thanks mate, I will hold out for the mini 311 then. I currently have a mini 700 and the speakers are great and compared to my friends nc10 there was a massive difference.
As I mainly use my netbook whilst travelling with work its a big consideration for me
just installed vista, and im still needing to get a few drivers, couldnt get my printer to work under 7 but still may go back to it, just wanted to try vista, vista scores are
3.1 - CPU
4.5 - MEM
5.9 - Aero
4.4 - Gaming
5.6 - HDD
Seems pretty swift in vista too
So, the size 'seems' the same as a 10.1"? Not a big enough increase to make life easier on the eye etc?
oh no sorry, its definately noticible and easier especially for my old eyes :D probs best to compare them side by side really unfortunately I dont have my nc10 anymore
