Samsung nvme
28 May 2007
Saturn’s moon Titan
So I’ve bite the bullet and got me of these is there any thing I need to do ?will I have to disconnect my other ssds before installing windows on it .
Is there any drivers in need ?
Regards scubes .
You forgot to end the sentence: ... are brand overpriced.
Wintoys10 has own NVMe drivers and can work perfectly well without any additional drivers.
And when installing (any) Windows always disconnect cables from other drives.
Microsoft is pathologically incapable to quality and other wise installer likely installs some boot data into other drive than what you select as target for installing.
You can install drivers from Samsung's site later. Also the Samsung Magician utility can be installed where you can set aside some space for over provisioning (will extend drive life)
Leaving empty space on drive, either inside partition or then some unpartitioned space, achieves the same.
