** SAMSUNG QUANTUM DOT 144Hz 1ms VA GAMING MONITORS EXCLUSIVE at OcUK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK and myself are very proud to announce the availability to pre-order now Samsung's latest state of the art gaming monitors with incredible features such as Quantum DOT, VA, 144Hz, 1ms, FREESYNC and more. We expect our delivery to arrive within the next 1-2 weeks.
The rumoured 34" is also true and OcUK hopes to take the first delivery of those in January and expect the price to be around £900. :)
Samsung C24FG70 24" 1920x1080 VA FREESYNC Gaming Quantum DOT Widescreen LED Monitor @ £329.99 inc VAT https://www.overclockers.co.uk/sams...tum-dot-widescreen-led-monitor-mo-230-sa.html
LC24FG70FQUXEN, 1920x1080 Resolution, 500,000,000:1 Contrast Ratio, 1ms Response Time, 350 cd/m2 Brightness, 2x HDMI Input, 1x Display Port, Freesync, 144Hz, Quantum DOT, 2yr On-Site Warranty.
Only £329.99 inc VAT.
ORDER NOW
Samsung C27FG70 27" 1920x1080 VA FREESYNC Gaming Quantum DOT Widescreen LED Monitor @ £429.95 inc VAT https://www.overclockers.co.uk/sams...tum-dot-widescreen-led-monitor-mo-231-sa.html
LC27FG70FQUXEN, 1920x1080 Resolution, 500,000,000:1 Contrast Ratio, 1ms Response Time, 350 cd/m2 Brightness, 2x HDMI Input, 1x Display Port, Freesync, 144Hz, Quantum DOT, 2yr On-Site Warranty.
Only £429.95 inc VAT.
ORDER NOW
Stock is quite limited unfortunately with only around 300 units of 24" landing in December and under 100 units of the 27" so we expect them to sell out.
We have one of each here including the 34" and in short I am completely blown away, I have not seen a single monitor on the market that can even come close to them. Once the G-SYNC versions arrive next year Samsung will be a true force in gaming monitors and the rest of the market will truly have to pick their game up to compete with these.
P.S. I have requested 27" 2560x1440 VA 1ms, 144Hz, Quantum DOT in FREESYNC & G-SYNC too, lets see if it happens. ;)
1080p? Pass.
Actually in fairness 1080p on a 24 inch monitor is perfectly acceptable but not on a 27, still steep though.
Unfortunately, I doubt they can make them sufficiently responsive beyond 1920x1080 yet, hence the 3440x1440 only doing 100Hz. If they can, then I'd skip both and wait for a 3440x1440 VA 1ms 144Hz.
I'm assuming these new 144hz 1ms VAs don't have the horrible max responsiveness values of the Sharp / AUO and marginally less horrible max responsiveness of existing Samsung VA panels?
I so wanted to like the Eizo VA and BenQ ones ... but found them so juddery it hurt my eyes. Whilst the existing Samsung ones aren't high Hz and never made any outlandish responsiveness claims, I still couldn't consider them.
Fire alarm keeps going off here because my money keeps burning a hole in my wallet!! :D
Best
Wulf
What is the excuse for that stand honestly. The Korean monitor using Samsung's ultra wide panel looks so much nicer because of it lol
Hi there
ORDER NOW
ORDER NOW
Do you perhaps know if the purple issue that most people have been experiencing with the C24FG70 has been fixed on the C27FG70.
Like this for example:
https://www.youtube.com/watch?v=XmFQ_vfPzfU
https://www.youtube.com/watch?v=9V1zXI0ggZM
https://www.youtube.com/watch?v=ob3eHXgUb84
The purple artifact is basically something that happens in somewhat dark areas, the colors will have like a purple color/hue to the screen. There are also some freesync issues with the C24FG70 like a flickering side and stuff.
Isn't that a bandwidth limitation? You need a DP 1.3+ card and cable.
Bring it on! GSync, please.
Why do people need a 27inch monitor... i struggle to look at all of my 24 inch.
and yes those stands look very big.
I want bigger than my 27". Why would you want a little screen? I find Marge screens more immersive though mine is 1440p. 1080p on 27" might be a little... Overkill
More monitors than not have issues with those grey banded websites ... but that CS:GO Dust2 example was bad ... :(
Pretty much, the purple thing bothers me the most. Though I have read somewhere that samsung is aware of it and can fix it with a firmware update at a repair center. So I assume the 27 inch won't have it hopefully.
Looks like it wasn't worth waiting for. Microboard screen for about 580 is the better choice it seems.
Hi Gibbo - does the CF791 run at higher refresh rates when you drop the resolution? It seems the previous version of the panel did, but from what I have read this will be using a different panel (LTM340YP04 as opposed to LTM340YP03). Thanks in advance.
