Hi folks,
Just wanted to get some good advice on this monitor,
I recently purchased one of these and overall I was very impressed, especialy with the 2d to 3d function.
Although there are a few problems that i found with this monitor, one of which was the oem bundled tridef 3d software. I currently use sli gtx 580's in my system, when i try to use the 3d ignition software to play a compatible game (Crysis 3 or Deadspace 2) I experience a split screen view, two identical images divided from the centre vertically.
Is this a faulty panel? or is this an issue with hardware or software?
I really like this monitor and it is a massive shame that it does not support 3d vision, and i do not know if its worth going for a completely different monitor that is 3d vision certified based on my graphics cards because its not certain that this monitor will be sli compatible which makes it kind of useless if it doesnt in the future.
There is only one 3d monitor that is similar to the Samsung that i know off and that is the Acer HN274H but i have the feeling after reading some reviews on this that the Acer will not have as good image or colour quality as the Samsung.
