Samsung Sata HD Help
24 Dec 2004
Hi
Just put a 160gig sata hd into my system and set it up formatting,
windows finds it fine but the safely remove hardware icon is in tool bar
when I click on it the new hd is there? Why?
Thanks
Mumpy
RJC said:
I think you can hot swop the drive. even though its your main drive.
Rob
Yes and no. SATA is hot swappable so appears in the Safely Remove Hardware list although you won't be able stop the system drive as there will always be locked files.
