Samsung SM226BW and BF2 Ghosting problems
15 Mar 2005
Hi everyone, I'm getting white halos around fast moving objects (planes, helicopters etc) in Battlefield (regardless of vsync). Is anyone having the
same problem? (I have an A panel).
As a quick test stand on the carrier and move around, I get a white ghost
from the AA gun for example.
Thanks
yep, talked about this in another thread....if you access the OSD factory menu you will probably find that disabling the "RTA" option stops this blurring issue :) I'll try and find the thread link for you, hang on...
Yes please, thanks
Hi again, I've found the factory menu and have the following options;
auto auto = on
pixelshift = off
country = english
What should i change?
none of those, there should be other options too? which panel is listed in that factory menu?
this is how to access the menu btw:
- Set contrast and brightness to 0
- Press the « Menu » button
- Press the « Source » button for 5 seconds (the second one on the right)
A hidden ''Service Function'' menu will appear including Panel Info on the bottom which clearly indicates the panel’s origin and reference.
this was the thread where someone had same issue, note my reply (as "Badd"):
http://hardforum.com/showthread.php?t=1184546
