- 21 Oct 2009
Hey guys, so here is the delio...
I recently purchased a 1TB Samsung SpinPoint F3 SATA drive to use as storage and to download my daily stuff to.
I have a Dell 8250 system running Win XP PRO (SP3). My system boots from an IDE drive and my new SATA drive connects (via a SATA cable) to my VIA VT6421 RAID controller which then connects to my motherboard using a PCI slot. Windows can see the drive fine, I'm able to initialize it just fine then go back to DOS and use Samsung's utility to prepare the drive for windows. This works great too and I see the new drive in the My Computer area.
It's accessible too and can be written to just fine. I can transfer data to it from my internal IDE, or my external WD MyBook and it works great. Transferring data from my new 1TB SATA to the internal IDE/external WD MyBook is the problem however - it's just so slow.
It's painful to watch and I don't understand how/why it is happening. If I can write to it from the other two drives at great speed, why can I not write from it to the other two drives at a decent speed to?
Moving files from the 1TB drive to another folder on that same drive also does not work, for example when I extract .rar files and set the destination to another folder on the new drive. I don't know much about this stuff, but I have to assume that the hardware is fine if the two other drives can right to it just fine?
The Samsung HDD utility does fail a "Loop" test when it gets to the 'Surface scan' part... the message I get is "Error AJ36: bad sector!" and I was advised to format the disk and re-start the test... I did that and still got the same message. Could the bad sector be the issue? I thought if it was, I wouldn't be able to send data to it at decent speeds from other drives but as I said, I can and the problems occur when transferring from the 1TB to other drives.
Unless writing to and transferring from disks are handled by different methods and the transfer method is extremely poor because it is affected by the bad sector?
Please advise on what I can do... I can send it back by the way, I have plenty of warranty with Samsung but I wanted to see if there was anything I can do to fix it myself. I'm currently scanning the drive for errors from the Windows error-checking tool found in right-click > properties > tools.... will report back.
