12 May 2016 at 09:45 #1 spluff spluff Soldato Joined 19 Oct 2002 Posts 2,599 Ive have a Samsung 950pro and Samsung 850evo on Asus Max VIII windows 10 Is there any speed advantages running the Samsung Software? I prefer not to run extra bits of software if u can get away from it
12 May 2016 at 12:05 #2 rickh rickh Associate Joined 26 Dec 2008 Posts 623 The only Samsung software that would make any difference is 'RAPID' mode. However, the consensus is that it's not worth bothering with: http://superuser.com/questions/7427...ble-rapid-mode-on-a-samsung-solid-state-drive So, no, don't install Samsung software unless you want to do firmware update.
12 May 2016 at 12:45 #3 spluff spluff Soldato OP Joined 19 Oct 2002 Posts 2,599 thanks for that ill not bother installing it
20 May 2016 at 13:42 #4 bledd bledd Don Joined 21 Oct 2002 Posts 46,870 Location Parts Unknown You could install it, then disable the auto-start. No harm in using it to check for firmware updates every few months.
