Has anyone had any experience with the 204b, for gaming mostly.
The specs on this model look outstanding to me and Im seriously thinking about getting one
Oh guess I should mention Im emigrating to US end of March and will be buying it there.
Product Details
Key Features Monitor Type Flat Panel LCD TFT (Active Matrix)
Size 20.1"
Contrast Ratio 800:1
Aspect Ratio 4:3
Max. Resolution 1600 x 1200
Brightness 300 cd/m²
Response Time 5 ms
Dot Pitch .255 mm
Color Depth 24-bit (16.7M Colors)
Viewable Picture Size 20.1 in.
Technical Features
Form Factor Desktop
Digital Video Input Standard DVI-D
Synchronization Range - Vertical 56 - 75 Hz
Synchronization Range - Horizontal 30 - 81 kHz
Max. Viewing Angle - Horizontal 160
Max. Viewing Angle - Vertical 160
Native (Recommended) Resolution 1600 x 1200
Regulatory Approval Energy star • TCO-99
Dimensions
Width 17.5 in.
Depth 7.9 in.
Height 16.8 in.
Weight 16.9 lb.
Warranty
Warranty 3 Years
Miscellaneous
Power Consumption 36 Watts
User Controls Brightness • Contrast • OSD Controls • Color Adjust • Position • Selectable color temperature • Sharpness • Gamma
Other Features VESA External Mounting
Exterior Color Silver
Platform PC
MPN 204BSILVER
Product ID 28937005
Product Details
Size 20.1"
Aspect Ratio 4:3
Response Time 5 ms
Dot Pitch .255 mm
Technical Features
Form Factor Desktop
Dimensions
Width 17.5 in.
Depth 7.9 in.
Height 16.8 in.
Weight 16.9 lb.
Warranty
Warranty 3 Years
Miscellaneous
Platform PC
MPN 204BSILVER
Product ID 28937005
