Samsung TV problem
24 Jan 2008
By Coffee cup...
I have 46ES6300 here and it was playing mkv's files over network just fine.
after latest firmware update it says that files are not supported...
anyone experienced anything like this ?
not sure what I can do....
at the moment am using servioo on my PC with all clips and videos.
all advise most welcome,
Thanks!
yes.
Tried that and it did help.
now again TV keeps on disconnecting every 30mins from network...not sure why..had this problem with servioo now and then...
have no idea how to fix this...or what makes it disconnecting.
still have no idea why suddenly servioo stopped playing some files when it was fine for ages..
need to check if TV will play those files from USB to make sure it is not TV ...
