SAN Advice - Urgent
I've seen HDC (Hitachi) mentioned before - I had a look at their SMS line and was told by the supplier something odd.
They said that they either come with a full compliment of 146gb disks or a full compliment of 300gb disks etc. Apparently if you want to expand, you cant swap disks or add a second tray, you need to purchase a new unit and pay an engineer to come in and replicate the data onto the new one......:confused:
Dont know how true that is but it put me right off
Sounds likely, I read a review for one and it said the disks were non removable. If you had a disk failure you had to swap out the whole unit. Although Hitachi would do an advance swap out so you could copy your data over. Sounds like a lousy design.
Yup their very low end kit (think its the SMS100) isn't scalable.
Their mid and high end kit is awesome kit though. Just installed two AMS 2100 FC arrays and they are running sweetly with a mix of VMWare, SQL servers, Oracle Clusters etc etc.
Last place I work had about 200TB of HDS storage and it was very impressive.
We use NetApp and even though my misses does work for them I couldnt recommend them enough, and all the women are smoking there ;)
Stelly
Stelly
Agreed.
Another NetApp user here. I am very happy with them to be fair even though there not the cheapest SAN on the market.
For STS replacation NetApp IMO are one of the best.
Andy
A woman who works for a SAN company full of other smoking women? surely not... where can I find one?
It was hard, believe me... its a great company, I get lots of interesting info and VM that use their technology to play with :)
Stelly
p.s. they grow on trees in my garden :)
Neither the MSA or the equalogic is enterprise. It is low end. In fact the MSA was made bt the server division of HP, not the storage division.
you sure about that?
the msa1000 in beta was based on SBB storageworks drives and MA8000 controllers (hsg20/21's), sure they move forward to incorporate the smartarray chipset but that was to promote DAS to SAN, was definitely still the digital swx team and not compaq proliant orientated. or if you like white/blue box alpha storage developments, akin to ma6/8000, esa8/12/16000 and later the eva/xp1024 platforms.
msa is definitely not an enterprise class solution but nor is it low end, its aimed at the emerging SMB customers
Ahh, I thought it cam eout of the server division! I know that the MSA2000 today is an OEM dot-hill box.On the grand scale of the storage I would definately put it at low-end and no higher. Nothing wrong with that - as you point out it's where it is aimed even though in defense of SMB I do see quite a few starting on some mid range SANs.
