SanDisk 256GB Extreme PRO SDXC card
18 Apr 2004
Milton Keynes, UK
Forgive me if this is the wrong thread for removal storage.
I bought 2x of these cards recently and they are rated at 200MB/s though both had the exact same serial number on them.
I ran some tests, and bought again a new memory card reader, SanDisk Extreme PRO SD UHS-II USB-C Card Reader. However, I'm only getting max speeds of around 90MB/s which sounds a bit sussed.
Do anyone else have these cards? Do you get consistently the same speeds as me or more closer to 200?
Are you talking about read or write speeds? 200MB/s is the maximum read speed but 90MB/s is the card's rated write speed.
My immediate thought was 'fakes' when you said they had the same serial number but I've just checked my five 64GB 170MB/s cards and found three have one number and the other two a second one so I'm less concerned by it.
I've just run one of my cards through H2testw and got 94.8MB/s for write and 143MB/s for read. I then found a Sandisk reader which gave me 155MB/s read.
So with a suitable reader, which yours certainly should be, the card should get close to its rated read speed. Is the port on the PC USB-C or USB-B?
That's what I thought. I've tried it on both my Macbook Pro and Windows PC via USB-C. I suspect fake cards, never mind I've returned them now.
