Sandisk Extreme External SSDs failing
12 Dec 2006
Is there another thread on this? I was reading about SanDisk Extreme SSD Externals failing a while.
Bit concerning because my primary external is one. But I didn't think the 500GB were effected.
Occasionally my 500GB would disconnect randomly. But today its doing it a lot. Reconnects when plugged out then in.
I've already got multiple backups of my data. Not worried about that.
I'm thinking I'll have to wipe the SanDisk and stop using it. It was bought October 2021. Anyone have problems with theirs?
I was put off Sandisk for life when when an SD card failed in a Dell pocket PC years ago.
Never bought one of their products since.
I read this and immediately thought of Psion :D
I used to do their Tech support back in the day just.. total nightmare at times. How things have changed!
I would consider Sandisk a decent brand but like any manufacturer, they can have flakey firmware.
Wonder can you even update it on an external SSD however?
OP it sounds like a firmware bug!
They've not issued a update for mine. Only the higher capacity models.
I had tried different ports, but not cable. Just tried that and its the same. Its encrypted so not worried about the data on it.
As it failing means I have one less copy of my data. I'm creating replacement "copy" on backup mechanical disks.
Once thats complete I'll probably try overwrite the SSD with a one time pass, before it fails completely. Then stop using it. I've heard it take months to get a SanDisk drive replaced at the moment.
So I deleted my data, reformatted the drive. Overwrote the drive with large media files. Deleted it. Reinitialised bitlocker. Filled it again with media. No disconnects. Did note the USB C port has a bit of movement.
Dunno what to do with it now. Use it as a secondary backup.
In fairness SanDisk came back offered to replace it. Though they closed the support call before I had a chance to reply.
Drive seems to be working of after reformatting and re-encrypting.
I've got one of these as a backup drive can notice it failing but it doesn't inspire confidence, is there any fix for this?
They did issue a firmware update for some drive (not mine) but I don't think it fixed it. Some reports of replacement drives failing. SanDisk haven't really sorted it out yet it seems.
I wouldn't use one as primary drive or sole backup anymore.
I wonder if Sandisk bought the dodgy NAND ram from Samsung.
Like the other thread about Samsung 870 EVOs failing.... a link between them perhaps?
