- 14 Jun 2004
- Newcastle U/T
Got one of these arriving soon
Are there any firmware updates I need to be aware of?
Extreme SSD Firmware Release notes
SanDisk Extreme SSD (120GB, 240GB & 480GB): version R201 (release date: April 27, 2012)
WARNING: If you already have the SSD Toolkit installed, then please update to the latest version of the SSD Toolkit application before performing the firmware update for the Extreme. You do not have to uninstall the previous version of the SSD Toolkit; the latest version will replace the previous version.
New changes since version R112:
Improved the robustness of the recovery procedure during power cycles and secure erases
Fixed an issue that would block a TRIM command sent by an application on Windows 7
Improved TRIM throughput, write performance, resume from slumber and checkpoints
Known issues:
None
You bought an extreme? The ultra was on offer yesterday
Check the site and just keep it up to date i assume
