This is the proposed build, what do you think? I have a Sapphire 6950 and a Seasonic 620w modular PSU along with Windows 7 64 bit.
All the prices are in Canadian dollars as I live in Vancouver.
LIAN LI PC-Q08B Black Aluminum Mini-ITX Tower Computer Case Item #: N82E16811112265Return Policy: Standard Return Policy
$109.99 select item 2 quantity of item 2
Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 996770 Item #: N82E16820226095Return Policy: Memory Standard Return Policy
$82.49 select item 3 quantity of item 3
Intel BOXDH67CF LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard Item #: N82E16813121484Return Policy: Standard Return Policy
$124.99 select item 4 quantity of item 4
Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500 Item #: N82E16819115073Return Policy: CPU Replacement Only Return Policy
$214.99 select item 5 quantity of item 5
Scythe Big Shuriken SCBSK-1000 120mm CPU Cooler
$33.99
$33.99
