Santa Cruz/Sonicfury vs onboard
18 Oct 2002
Edinburgh
I've stuck with my videologic Sonicfury since my old Thunderbird 1.4 rig, but I'm now upgrading to Conroe and will have the Gigabyte DS3 onboard sound as an alternative... It uses intel "high definition 8 channel audio"
Shall I give up on the old PCI soundcard, or will it still offer better sound quality?
EDIT: corrected grammar garbage.
'some' not all! onboard soundcards suffer interference like when you move your mouse etc you might get a small whining noise
^perhaps this is just really old onboard soundcards, the only onboard sound i've ever used on my main rig was my nvidia, which was awesome 5.1 sound
Yes, the only onboard that I have had thats worth bothering with was also nvidia for me too, which was the SoundStorm on the NF7S. Funkily enough, its only a realtek sound device too! - just shows doesnt it?
I have so-called high definition Audio on my P4 3.6 and to be quite honest, its among the biggest piles of doggie doo I have ever had the misfortune to use and if that board caught fire, id probably dig out some marshmallows, so just because it says its something, its not always the case.
I also have a couple of TBSC Cards, and while they are a little dated now, and yes some motherboards are better quality and perhaps better performance-wise too in games, at least you know what you get with the TBSC / VLSF, and thats a good warm sound... Not too harsh like Creative cards, but not quite high end like the Philips / MAudio etc
AFAIK the TBSC is no longer supported too, as I have not found an updated driver for years.
As for getting a mate to swap cables over etc, this I think is a mute idea. I think the only way you can really test it, is by using the onboard for a fair while, trying out various things to put it to the test properly, playing various styles of music and various Audio-heavy games etc, get the Balance of it just right for your speakers and so on, and then just think for yourself how well it compared against the TBSC... Then, should you want to re-try the TBSC, just plug it in and have a play about.
You can in most cases, run them alongside each other, so doing that might be an option, and using the control panel thingy to select the output device, but also remember that in some cases, even if the sound device is not used, it can still slow the system down, and not let you have a fair comparison when you are loading the running one.
My Asus A7N8X de luxe mobo has Sounstorm, but I found the TBSC better for music (stereo). But I am not a gamer, nor watch many DVDs or TV on my PC.
Thanks for your input guys. I'll see what I think when I get the rig set up. Not too concerned about performance of either card - it'll be a conroe rig, so the tiny amount of FPS dropped by one sound solution isn't worth worrying about too much.
I watch lots of DVDs, and at the moment my soundcard has analogue out to my AV receiver (Denon 1906, connected to some Kef speakers). This might warrant a nicer sound card or a dedicated DVD player, but I haven't got the cash for that any more. But I also play too many games, and it's quite handy being able to multitask dvd watching and MSN/work with only one audio input.
Oh, and hello Bledd! Long time no speaky on MSN.
yeah, very long time
msg me sometime soon, i removed loads of people from my list, might have caught you in there :(
click the link beneath my sig, had a bit of a rough time this year!
Mmmm - we've definitely msn'd since the UC and lovely pictures bit. Pity you didn't get any during operation photos - it's all the gorier when you're scrubbed in to surgery and there's blood squirting... Will pester you next month - I should have a little more time free :)
