Guru3d got theirs to 925 core.
They usually send hand picked cards to review sites
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
They usually send hand picked cards to review sites![]()
I dont have a ruler, @ 11 inches ill have to use something else
Of course. I'm saying that bit-tech must be wrong. Most of the other reviews have some kind of overclock info. Did you read the post I was quoting?
Cheers for the mini review mate.
Really would like to try one but the noise is putting me off. Never bought a 4890 but had a 4870. Is the 4890 louder than the 4870 or about the same?
If you were closer m8 I'd say pop over to check it out
But imo the 4870/4890/5870 are much of a muchness when it comes to noise levels (from memory)
Si
