"If you can't say something nice, don't say nothin' at all. "
— Thumper
I do apologize i didn't mean to be offensive.
— Thumper
What make PSU do you have? (This is important)
Did you have an Nvdia card installed before you got the 6970?
Edit: i can see you used to have an ATI card previously
I would 100% reinstall OS
When OS is installed,just install the CCC and the chipset drivers etc and then run your benchmarks and see what you get
It cant be ATIs drivers if it was we would have countless 6970 threads here
When i have bought new cards in the past,i have sometimes had similar issues to you,a OS install 99% of the time fixes things,try it
People always blame the drivers rather than themselves
I have had zero issues with ATI drivers
I have to say I agree with this as well, AMD drivers work just for me (and Nvidia drivers as well). I would if there's driver issues then you would expect a board full of threads talking about the problem but 9 times out of 10 driver issues get blamed for indivdual issues. As for hardware faults the failure rate I would expect to be 2 to 4%.
Pretty daft thing to say there... although I've never had any problems either, there are so many different hardware/OS configurations that people have, some are bound to experience problems which aren't their fault.
http://www.rage3d.com/board/showthread.php?t=33961798
I used this, just be smart about the ccleaner, and ONLY delete the files that state ati unless ur absolutly sure about it.
(a save regfile is a good idea)
I followed this and fixed some issue I got with the preview driver (dont use it on 6900 series)
If I'm having problems and I suspect it's because of driver install issues, what should I do?
This is what the Caveman does for Driver freshness. You'll need two free tools - CCleaner and DriverSweeper. You'll also need to know how to reboot into safe mode, and to be able to use 'common sense'.
Disable Eyefinity groups, Crossfire, if enabled
Optional - Enter Device Manager: Uninstall Display Adapters and check box for 'Delete Device Driver'
Add/Remove Programs: Remove currently installed Application Profile updates (if installed)
Uninstall CCC and Display Driver, using Catalyst Install Manager Custom mode (Don't express uninstall if you have an AMD Chipset)
Reboot into safe mode
Run Driver Sweeper for ATI Display Drivers, don't reboot.
Run CCleaner for Registry - run Analyze and only select ATI entries for removal.
Delete the following folders (applies to Vista/7)
SystemDrive:\ProgramData\ATI
SystemDrive:\Users\username\AppData\Local\ATI
SystemDrive:\Users\username\AppData\Roaming\ATI
Reboot to desktop, run Express install on desired Catalyst driver & reboot if prompted.
Install all Application Profiles newer than Driver release (i.e. 10.3whql/a/b would use both March & April profile updates).
Enjoy!
I
