Hi all.
I just got a AX850 and 2xSAS drives (from a new server)
Got a SAS controller card, and its working fine.
Issue is that the SATA cables im using do not fit correctly.
So for a tempory mesure I have modded them, by cutting off the edges were that SATA closes off.
The SAS data and power are not 2 seperate units...
So I opened up the edges of my SATA cable and SATA power cables, so now they fit.
But they fall out easily.
So as such I need to find SAS power and SAS data cables.
I would love the power to be modular and fit right into my Corsair AX850 if possible?
Thanks
Thanks
