Basically it's to SCSI what SATA is to IDE/ATAPI - the same basic protocols over a serial cable rather than a parallel one. SAS has one very distinct advantage over SCSI in that you can connect SATA drives to a SAS controller (but not vice versa). This gives you the ability to use very quick 15krpm drives for a boot disk/array and cheaper larger SATA drives for storage all on the same controller / backplane.
