Sat Nav Internal Flash Memory, HELP :(
11 Mar 2006
Hi,
I have a satnav and was attempting to update the software on it.
I plugged in the satnav to my PC, gave me the 2 internal drives in 'My Computer', both were fully accessible.
I copied the stuff off them as a backup.
Then I tried to format to get them completely wiped clean.
Now I can't access the drives at all, they come up in 'My Computer' but just says 'please insert disk' when you double click on the drives.
Can I retrieve the drives? I can't get the satnav working again without them =|
any help would be greatly appreciated!
Cheers
Evesham have gone bust I think =|
So far, i've just downloaded the HP formatting tool, and that actually recognises the drives with the correct sizes (eg 199mb and 19mb).
However, I go to format the drives using the tool and it basically says 'Write Protected'
How can i get around this?
Cheers
