Several hours of pain today and no joy
P5K Premium & Q6600 & XP Pro 32bit SP2 slipsteamed
SATA 2 = WD 500Gb AAKS
SATA 4 = Pioneer DVD-RW
IDE = WD 80Gb
Also got FDD
All devices discovered in bios
Wasn't planning on using RAID but maybe SATA AHCI
Set bios to SATA AHCI, reboot back into bios to confirm both SATA drives are discovered with AHCI
Have created 3 seperate floppies as 64bit ICH9R/IMSM "makedisks" for the F6 install
I boot off my DVD with XP SP2, press F6 then when prompted press S to load from floppy, I get the list of drivers and select ICH9R AHCI but get "iastor.sys is corrupt" from all 3 floppies, each floppy from a different source, ie Asus CD, Asus website and Intel download page
Just noticed on the screen where you press S to load from floppy "Setup was unable to load support for the mass storeage device you specified, currently, setup will load support for the following device(s)" - this is even displayed before I press S to load from floppy
<none>
Thing is I've not been asked to specify, I thought you simply boot from DVD then press F6
Any help would be great, so frustrated am thinking of setting as SATA IDE !
IDE = WD 80Gb
Also got FDD
<none>
