SATA Cables - Which?
25 Oct 2009
Caerphilly
Have 2x SATAII hdd's on the way.
I was just wondering what sata cable's would be most sufficient for them? I'd prefer one's that a "clipable" , IE its secure on the hdd's sata port.
I've had too many problems in the past with cables being knocked out by the slightest of touches.
Cheers, Rhys
It really doesn't matter, all of them is +/- same. If you want one with clips, then look at A.C.Ryan brand (i have many SATA cables from them), unfortunately it seems OcUK doesn't have them.
AK-CB053 - 45cm straight
AK-CB054 - 100cm straight
AK-CB055 - 45cm right angle
AK-CB056 - 100cm right angle
All of those have the latch connector. They're the standard red cable with black connectors.
Doesn't look like Overclockers stock them which is a shame, but hopefully that helps.
The Akasa ones that OcUK stock do have the extra secure metal latches on them. Although it depends on if you want the colourful bling with them.
Thanks guys.. I have a foxconn cable laying around so I might try that.
I'l have a look at these Akasa ones too and see whats happening..
Cheers, Rhys
