You can get a PCI Sata controller card, all you do is plug it into a spare PCI slot and and connector the HD's to it and your sorted, infact I got a spare one unused in my room, was planning on using it but upgraded my mobo so not had the use for it, I live in newcastle also so if you want it give me a email and im sure I can give it to you for fairly cheap (like a tenner or something if you come get it, or £15 if you want it delivered to your house).
It uses the Silicon sata controller chip.
