Sata controllers and JBOD.
Hi all, I currently have a Asus A8n SLI-Premium.
All 4 of the standard SATA ports filled, if i buy more hard drives can I only run them in RAID on the silicon image controller or does the silicon image controller allow you to run them as "normal" hard disks, I don't want to run RAID and I've also heard that if controllers offer JBOD they can lock that hard drive to only that controller is this true?
Also, if I can't do this on the Silicon RAID ports will I be able to acheive this on one of those adaptec controllers on ocuk?
Thanks
Thanks
The review did mention it uses a ATA100 -> sata bridge so if you wanted to RAID 0 it wouldn't be worth it but for general storage it would be fine
