Hi
I have two SATA hard drives on my PC, main one being 250Gb and second being 200Gb. Both are Seagate and almost identical spec from what I remember of them.
The main HDD has Windows on it (which I can boot into with no problem) and even has a few other partitions on it (Ubuntu etc) which I have been messing around with.
The second HDD all of a sudden is no longer working. It was not a bootable one, just used for data storage, but whilst playing with my main HDD with a fresh install of Windows etc, the second HDD was my only place of storing all my data.
Anyway, that's beside the point. I have tried the main HDD in both SATA ports on my mobo, trying both cables in all combinations and when ONLY that hard drive is connected it works fine, I can boot into Windows etc. When the second HDD is connected to either port, using either cable it is not recognised during the boot sequence. As in there is no device detected on either SATA port (obviously I know Windows will not boot!!)
The thing that stumps me though is that when both HDDs are connected, neither of them is detected! Weird eh?
I imagine it is the fact I only have one SATA controller on the mobo (Abit AV8 3rd Eye Skt 939), but would the defected HDD overpower the working one?
Also, any suggestions what to do with the one that isn't being detected to get the data back? A Linux live CD wouldn't be too much help if the physical drive is not detected would it?
All suggestions welcome!
Thanks
Marco
Thanks
Marco
Just make sure it's well sealed to avoid condensation, maybe even bung in a silica bag if you have one lying around. A small amount of rice wrapped in a muslin bag is also pretty good at absorbing water if desperate, but if any doubt, letting it come back to room temperature first might be the only option to avoid killing it even more.
