SATA hard drive issue
19 Jan 2012
I am trying to run a hard drive checker on a WD hard drive. The drive is SATA. After the program runs it says no hard drive found? There is hard drive installed and it has windows 7 on. I can boot into windows ok. I just want to do a full hard drive check to see if that has any problems.
I know it is a BIOS setting I have to change but which one? I am using an ASUS P8P67 Pro.
Sounds like you're using some sort of bootable hard drive checker?
Might have to change the AHCI mode over to IDE?
