Sata > IDE convertor?
14 Jul 2003
Anyone know if you can get these? I have a brand new SATA HDD I'd like to use, was going to upgrade my PC but now I want to wait until Feb/March to get a new motherboard/CPU/graphics card.
I have an IDE > Sata convertor but it only works one way, can't convert back.
Ah cheers, I'd only be using it to story documents, MP3S etc on. Nothing that I really need to worry about performance with. I currently have them all on a very old maxtor which I'm sure is starting to generate bad sectors so I'm sort of out of options :)
Yes you can get them. Have a link to an item on a popular auction site, but probably best not to post it here (mind you, OcUK don't actually stock these...)
Just do a search for "ide to sata" on said popular aution site. Loads of them, dirt cheap too.
(never used one though, so no idea if they're any good!)
