Hi guys,
I've built my first pc with a sata drive. Its a Gigabyte EP45-UD3L Intel P45 mobo and a WD Caviar Black 1 TB.
In bios I know that I can't run AHCI, so I need to turn this off as I didn't install the Intel desk drivers when installing XP Home. But the Bios describes this as setting the hard drives to PATA. I don't want my drives set to PATA!!!
I've run HD tune (having trouble loading screenshot, try from home later).
On the info page it shows the drive supports ATA/ATAPI8-SATA II, active UDMA Mode 5 (Ultra ATA 100).
I'm a bit confused its a Sata disk connected to the sata port but its being reported as Ultra ATA 100, like an PATA IDE disk.
I'm a bit confused, is my Sata disk running Sata II 300 or as a 100 ATA drive?
