Sata power terminals voltage
26 Jul 2017
Evening all, got an older CCTV recorder and the hard drive doesnt show up on the diag page so you would assume its the drive as it mostly is. BUTTT when plugging it into my caddy it shows up and after doing a format i can actually use it
Now after some checking and fiddling, i manged get the dvr to show A hard drive with the power coming from another dvr but the data going to the original one. Tried with a different sata power cable on the original DVR but still nothing, does this mean that there is no power coming from dvr molex to sata connector / cable?
Another problem is, whilst fiddling etc.. i broke corner part of the sata connector as it goes into the drive. Namely the corner where it looks like a reverse r part broke and when i connected with a cable a burning smells comes and it looks like the plastic is getting a bit melted. This mean that this drive is also gone and unuseable?
Hopefully havent confused the issue people
Thanks for any help
Any sign of burning should be a real concern and changing the molex to sata power cable is simple. To check theres power disconnect sata cable and plug fan into the molex if you have one.
A few pics would be good.
