Hey guys, i've just got 2x 250g SATA2 hard drives and im currently trying to install them. My motherboard will accept SATA 1 and i've been told there backwards compatable.
When i try to install it, the maunal for the motherboard says "go to advanced > onboard devies configuration and make sure the onboard promise controller is enabled" and it is enabled.
Then it says "set the operating mode as raid" which it is.
Now i want to use RAID 0 (performance) so it tells me to do this
Boot the system and when MBFastTrak378 displays No Array defined, press CTRL + Y"
Then it says "Select auto setup and choose Optimize array for and select performance, the mode should display stripe.
Press any key to reboot. Once the array is created, use the FDISK utility to format the array as a single hard drive.
Now i dont actully get the FDISK utility (unless im having a blonde moment)
So it loads through into windows, i press F6 to install the RAID drivers from floppy. I have downloaded the right ones and i select the right ones when installing the drivers. Once i've selected them and continue with the windows install, it says there is no hard drives there to install windows on, yet the Promise controller is saying i have 2 in RAID 0.
Any help would be great, as my girlfriend needs the computer for a Uni assignment.
Thanks
Thanks
