SATAVault 4X HDD 1U Rack-Mount SATA and SATA II Hot-Swap Case
18 Oct 2002
Liverpool, England
Does anyone know if there is a company that manufactures a case like this?
The one below is from an American website and it does not say who manufactures it (It looks exclusive product for them).
I would be grateful for any help as I really need one...
Please do not link to shops.
SATAVault-4X1U is an external 3.5" HDD 4-bay JBOD, with 4 SATA shielded connectors in 1U form factor. It has LED indicators and buzzer for environment detecting.
Features
1U design
Supports 4 S-ATA HDDs
Quiet ventilation fan
Aluminum outer case
Built-in power supply
Specifications
Design 1U Rackmount
Host Interface Serial ATA x 4
HDD Interface Serial ATA x 4
Hot-Swap Yes, support both Host and HDD
LED indicators of each drive tray White - Power on indicator
Blue/Red - Busy(HDD Accessing)/HDD Fail indicator (*HDD fail signal depending on host adapter/controller)
LED indicators of Environment Detect POWER on LED - blue
FAN normal - green; fail - red
TEMP normal - green; over 50°C - red
Cooling 2 blowers
Alarm Buzzer Beeping when any ERROR occurs
Dimension 455mm (D) x 483mm (W) x 44mm (H)
Material Aluminum & Plastic tray face
Power Supply Input: 90 - 230V AC 50- 60 Hz
Output: +5V and +12V DC 150W
There is a case that's in that form but it pulls out from the rack on rails and you then replace the drives through the top of the case. The result is that you don't waste 1U on just 4 drives.
That sounds interesting. It does not have to have front access.
Who makes does?
I can't remember - a mate has tested these (as it caught my eye too). I'll ask him tomorrow.
Basically the top looks like a nuclear sub, to replace a drive the rack comes out and the drive holder flips through 90deg and can then be pulled out.
Have you asked him yet ? :)
Doh.. good point. Mental note made.. should see him sometime soon (spent most of Feb in an aeroplane - andorra, dubai, barhrain, manila and hong kong).
