satellite to aerial adapter?
10 Jan 2012
UK
Hey I have a tx-p42st60b TV, it only has a aerial socket.
Is it possible to connect a satellite cable to the aerial socket (via an adapter) to get a freeview signal?
Plenty of cables online available, but not sure if they actually work.
But we have a TV connected via the satellite downstairs (normal connection on back of TV) and it says its Freeview when on the TV guide screen. doesn't mention freesat.
You don't have a terrestrial tuner connected to a satellite dish and picking up a signal. You need to double-check what your setup actually is.
The dish we have was used for the Sky box downstairs. We cancelled Sky awhile ago. Its just a normal satellite that Sky put there years back.
Both the other TV's in the house have a satalitte connection on the back of the TV and are connected via that and both of them say its Freeview on the tv guide's (icon in top right when on tv guide), nothing to do with Freesat is showing up.
Cable: There used to be just ordinary TV coax cable, commonly referred to a "Low Loss Coax" and that was perfectly okay for analogue TV. Then came satellite and with it a higher grade of cable was needed for use between the dish/LNB and receiver. The old brown low loss coax wasn't good enough. The new cable was better engineered but more expensive as a result: hence 'satellite cable' was born. Analogue TV aerial installs used the low loss stuff. Satellite (also analogue at the time) used the better stuff because it was better at handling the higher frequency signal.
In the late 90's the terrestrial TV market started the phased introduction of digital TV. The new standard required a higher grade of cable. In short, satellite grade cable became the preferred standard for TV installation too.
Today it's still possible to buy low loss single screen coax, but no self-respecting installer would use it. Most of the rest of what's sold is double screened coax. There are different qualities of it; RG6 is a bit crap but cheap, WF65 is the commercial equivalent to Sky's thin shotgun cable, WF100 is the good stuff because it's all copper. You'll see retailers refer to "TV coax" or "Satellite coax" depending on who they're selling to, but the fact is that this stuff can be used for either application. What determines the result is the source device which would be either an aerial (for Freeview) or a satellite dish LNB and then the corresponding type of receiver at the other end.
Cable alone can't change one signal type to another any more than your phone line can translate Chinese in to English. Even if the cable is marked up as for satellite use, if there's a TV aerial on the end then you'll get TV aerial signal out of the other end.
So how come the other two TV's show its Freeview that is coming through the satellite cable? Both of them have the Freeview icon in the Tv Guide screen.
What happens if you disconnect the satellite cable (BTW does it unscrew).
Andi.
Yes its the screw kind.
I don't know what you mean by if I disconnect, the only signal going in, is from the satellite, If I disconnect them, no signal.
Just its showing as Freeview on both of the TVs. Doesn't say freesat anywhere.
There could be lots of reasons. Without some extra information and pictures from you then we are all working with only half a story at best, so in return all we can do is tell you how things should work. It's for you then to investigate at your end and find out what's really going on with your system.
Satellite reception requires power from the receiver to make the LNB work. That's part of the reason why a single satellite feed can't be split between two or more receivers. The LNB is a driven device. It changes between four reception states based on the voltage and polarity. Splitting a single LNB feed means that two or more receivers working at the same time are both feeding voltage up the coax to the LNB. Sooner or later there will be a clash.
The fact that your TV has am F connector for an input could simply mean that there's an adapter plugged in.
Did it use to say freesat?
Can you find the tv model information.
Andi.
I'm struggling to believe your using freesat right now, i think your not using the dish at all.
Prob an Arial wired using the screw connectors.
Post some photos of the back of your TV where this satellite cable connects to. And of the EPG and/or tuning menu.
The other two TVs are not getting Freeview from a Satellite dish. My guess is they are connected to an aerial by the same type of cable as the dish.
